Howdy!
I have an issue with my pc front panel case lights, to be more specific I have 2 led lights, one that looks like a cylinder logo for the HDD and one with a light bulb logo, the cylinder is red the light bulb is blue.
The issue is that I put the right connections on the motherboard but is a blinking light bulb for HDD in blue and the cylinder logo led is off-nothing shows.
I tried to change the position. i can't manage to light up the cylinder-led light for HDD.
What I'm missing where can be the issue?
https://linustechtips.com/topic/1331673-pc-case-front-panel-lights/
Just swap between PWR_LED and HDD_LED. They can go both ways.
24 minutes ago, ExclusiveLTT said:
Howdy!
I had this same problem with something else and it turned out my LED needed to be hooked up to SATA power, since the cable for it had SATA power and I just didn't notice. Maybe see if it has SATA or Molex?
