Hi, currently running i7 9700KF @5.2ghz stable at 1.34v.
But cannot have it stable at 5.3ghz, i made a quick test by lowering my nzxt x53 240ml fan and pump speeds and the CPU became unstable at even 5.2ghz so i figured its a cooling issue, since some cores suddenly hit 85.
Can i get it to reach 5.3ghz or even higher with better cooling solution?
Anyone have it or had it can share their experience!
https://linustechtips.com/topic/1331609-9700k-max-overclocking-capability/
Sounds like you are almost there. If you kick it in the cores you could probably squeeze another 1-200MHz.. It will take it too you just gotta be able to cool it.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
