Minecraft only has like 80 fps and when i start recording, it drops below 60 fps. My specs are in signature. Cpu temps are like 60 while playing. GTA 5 runs at a stable 60 fps. X-Plane also doing just fine. I am not home so expect not to answer  asked questions instantly.
Specifications:
MOBO: AsRock B450 PRO4
PSU: some kind of Corsair 80+ bronze
CPU: AMD Ryzen 5 3600x
GPU Radeon RX590
RAM 16 GB G.skill Ripjaws 3200mhz
Fans: Xilince and Aerocool
https://linustechtips.com/topic/1331121-low-fps-on-minecraft-only/
Enable XMP, allocate more than 1GB to minecraft (4GB is the maximum for vanilla), and install optifine. Do all 3 at once and see what happens.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
It's pretty standard to get FPS drops when recording, as it puts an additional load on both your CPU and GPU. If you were using an Nvidia GPU then I'd recommend that you record with their specific encoder, but you're not, so as far as I know, you'll just need to make do with lower FPS when recording.
Desktop - i5-9600KF @4.8GHz all core, MSI Z390-A PRO, 2x8GB Corsair Vengeance 3000MHz, MSI GTX 1660S OC 6GB, WD Blue 500GB M.2 SSD, Seagate Barracuda 2TB 7200RPM HDD
Laptop - ASUS ZenBook 14 with ScreenPad, i7-1165G7, Xe iGPU 96EU, 16GB Octa-Channel 4200MHz, MX450 2GB, 512GB SSD with 32GB Optane
Old Laptop 1 - HP Pavilion 15, A10-9600P, R5 iGPU, 8GB, R8 M445DX, 2TB HDD
Old Laptop 2 - HP Pavilion 15 TouchSmart, i3-3217U, Intel HD 4000, 4GB, 1TB HDD
iPad 2018 - 128GB
iPhone XR - 128GB
Ma boi minecraft is spoiled with 6 gigs of ram and running optifine
Specifications:
GPU Radeon RX590
Chunk Render settings? 16 should be your standard cap. Also check for the CPU and RAM usage in the F3 menu.
Usually i have 16 chunks but i turned down to 8 cause of lag. Also once im loading 1.8 mc it only goes up to like 50-60%. In a nutshell, both usages are not critically high.
Specifications:
GPU Radeon RX590
