Budget (including currency): 1000 EUR
Country: Italy
Games, programs or workloads that it will be used for: mostly gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 1080p 144hz
Hello, i'm looking to build a new pc at around 1000 EUR without GPU for now, this is what i found after researching:
PCPartPicker Part List
CPU: Intel Core i7-10700 2.9 GHz 8-Core Processor  (€310.00)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  (€34.99 @ Amazon Italia)
Motherboard: Asus TUF GAMING B560M-PLUS WIFI Micro ATX LGA1200 Motherboard  (€153.99 @ Amazon Italia)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  (€106.90 @ Amazon Italia)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  (€82.51 @ Amazon Italia)
Case: Fractal Design Meshify 2 Compact TG Dark Tint ATX Mid Tower Case  (€109.58 @ Amazon Italia)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€109.76 @ Amazon Italia)
Total: €907.73
Generated by PCPartPicker 2021-04-21 15:01 CEST+0200
How is it?
I will get a 500-600EUR GPU around next year (at MSRP i hope)
https://linustechtips.com/topic/1329617-midrange-build-need-help/
Go with an 11500. The CPU itself is around 5 - 8% slower in gaming, but the IGPU is significantly better. Also it's a bit cheaper. I also changed the SSD and RAM.
You may also want more storage
geometry is hard
b550 > x570
Value of 2 extra cores might not be used in games, but is worth taking a slightly worse igpu if you realistically arent going to play any games in the short term on either of them
Well OP said that he was using the build for "mostly Gaming" and he was planning to buy the GPU next year
geometry is hard
b550 > x570
3 minutes ago, curiousmind34 said:
Seems ok, but I would go for an sn550 1TB or just add a hard drive for more storage
I already have a 1tb hdd, no problem for that.
3 minutes ago, Kerbwin98 said:
Say which games please becuase
If you only play minecraft, you could vuy a pc of ~250€
Thats essential for asking of pc builds!
Right now i just play league of legends, but i would like to play triple A games like cyberpunk, witcher 3 etc.
The 11500 is around 280€ with shipping, so around the same price as 10700/k, do you think is that better? GPU is not really important right now.
Hmm, okay I think the 10700 IS the better deal then. Not sure if the "K" model is worth it tho, considering that you are getting a B560 board.
geometry is hard
b550 > x570
38 minutes ago, Dylan96 said:
10700 is 300€, 10700k is 314€
I could get a ~180€ Z490 board for the k cpu.
But with the hyper 212, do you think i will feel the difference between 10700+b560 and 10700k+z490?
not worth it getting k series imo they cant overclock that much anyway
