Hello,
i recently bought a new PC Case. Link: https://www.amazon.de/-/en/Empire-Gaming-Diamond-Plexiglass-Addressable/dp/B07ZRXPKXY/ref=pd_ybh_a_7?_encoding=UTF8&psc=1&refRID=RM8JN86VRY1J0QGQJYR6 . The airflow is of course a bit worse than it could be, because the front panel only has side openings at the top and bottom making the middle fan unefficient. I looked at other cases and i saw similarities in the build structure and so i wondered if i could change the front panel to a mesh one to improve my airflow. Do any of you know where to look for such accesories? When not, do you have other suggestions? Unfortunately i cant return the case anymore. Any help would be appreciated.
https://linustechtips.com/topic/1329248-front-mesh-panel/
Are there other fan slots you can move the fan to to make the airflow just a bit more efficient. Super easy compared to case modding.
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
https://linustechtips.com/topic/1329248-front-mesh-panel/#findComment-14666531
ll a case would depend on your budget most of all. this particular case sucks because it places the fans about as close to the front panel as you can get so no airflow over and thru the fans. i would suggest you look into the fractal design meshify series of cases becase they have a mesh front that does allow airflow or i would look into a bigger case than what you need. for me i went from a mid tower case to the corsair obsidian 1000D super tower case so i never have to worry about a case upgrade again. i would also not look into any case from a company that when you search their name, they only pull up ebay or amazon results.
https://linustechtips.com/topic/1329248-front-mesh-panel/#findComment-14667732
