1: sometimes when I start my computer(stays problem until i reboot((sometimes doesnt fix)) and I try to open, say settings/files/task manager,furmark/ect it will do so very slowly, like in 30 seconds (normal is practically instant)    I don't have any programs that would cause this to happen and i only have like 5 start up apps: discord/steam/gputweakII/armory crate
2: (often paired with #1) when I right click on any program in the taskbar nothing happens(on some boots it works fine) also if i try typing in the search bar it wont do anything  BUT i can type if I hit windows key on keyboard seemingly because it makes the text cursor(insertion point) appear there
3: with gup: gpu will have random spikes in fan rpm    and no I don't have a weird curve   there is nothing about my fan curve that would make it jump to what i would guess is about 80-100%    the reason i say "about" is because the spikes don't register on the graph
4: cpu: the 5600x is only supposed to draw 73w(my friends wont go past 73w and is pretty good at overclocking) but mine, will go to 80      also its  t e r r i b l e  at overclocking, basically got the dumpster juice of the silicon lottery
sort of 5: earlier in the year i had an issue where i was playing game and everything suddenly froze, and from then on only certain programs wold open, couldn't even run diagnostic tool because it would just close    did a fresh install and same thing happened a month later     got a new nvme (rip $130) haven't had a problem since, however, it hasn't been that long(1.5 months) so i'm still cautious  (i have a fresh install on new nvme)     *** FIXED ***
so there you have it, the main parts about my computer that no one else seems to have and that drive me insane   can you please help me?
Ryzen 5600x
2070
Samsung nvme (500gb at 50% free)
decent cooling (max when gaming 70c)
750w psu (overkill ik)
b550 strix
https://linustechtips.com/topic/1329115-various-computer-issues-please-help/
<-- Moved to Troubleshooting -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
