In the case of a top mounted radiator, I don't think it matters at all since the rad will be on the same level.  If it was front mounted that would be different.  Most people just mount it the other way for aesthetics.  In terms of which way the pump is rotated on the socket, intel-wise it doesn't matter.
Bobbyct
Main Build: Intel i7 10700k | EVGA Nvidia 3060ti FTW3 | Corsair RGB Vengeance Pro 4x8 @3200Corsair 465x iCUE Smart Case
https://linustechtips.com/topic/1328573-aio-pump-question/#findComment-14661679
