So i build a new computer (amd ryzen 5 5600x, asus rog strix b550-f gaming, 16gb ram,corsair cxm 750,ssd 500gb cant remember the name and rn i have gtx 960 but i have ordered the rtx 3060 ti and phantom eclipse p300(so my problem is that computer doenst turn on but my motherboard led gets power and fans are not moving when trying to start up. My friends dont see the problem on the pc so does anyone else know or can it be damaged already. I have updated bios too
https://linustechtips.com/topic/1328451-help-with-my-pc/
28 minutes ago, Mister Woof said:
Is your display plugged into the GPU, not the motherboard?
Well rn my gpu is not plugged to the computer cuz i will prob try to get refund for my motherboard cuz i think that its broken at the factory. And what do u mean by display xd i am not so smart about computers
https://linustechtips.com/topic/1328451-help-with-my-pc/#findComment-14660632
Motherboard can't do display out with your CPU - if you've plugged your display into the motherboard nothing will happen.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1328451-help-with-my-pc/#findComment-14660724
