This is my current setup
I recently got a 5 pack of fans, but here’s my issue
I can’t seem to install the fans (as intake) on the front of the case, because there’s no supported mesh or place to do so.
So I was wondering what I should do with my case fans considering that I can’t setup any intake fans on the front of the case
Should I install another exhaust at the top?
Should I install an intake at the top?
Can I install both exhaust and intake at the top?
https://linustechtips.com/topic/1327500-case-cooling-dilemma/
Wish there was a better view of the front. I can literally see the place for the fans, but can't get a sense of where intake is coming from. Are there vents on the front side?
Also, do you know the make and model of the case? That would expedite matters greatly.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1327500-case-cooling-dilemma/#findComment-14653772
Do they not fit on the mounting brackets in the front of the case or is there not enough potential airflow?
Because all those brackets on the righthand side will fit fans im pretty sure
What is the case model and fan size you have?
Cause it looks like you have a ton of space
https://linustechtips.com/topic/1327500-case-cooling-dilemma/#findComment-14653774
https://linustechtips.com/topic/1327500-case-cooling-dilemma/#findComment-14653783
https://linustechtips.com/topic/1327500-case-cooling-dilemma/#findComment-14653784
11 minutes ago, James Evens said:
yes
4 minutes ago, James Evens said:
It is any way for looks.
Ryzen 7 4xxx should be the highest TDP part with iGPU and well below 100 W.
If that’s the case what should I do, add another exhaust on the left hand side (Of the top) closer to the existing exhaust, then add an intake on the far right hand side (Of the top)?
https://linustechtips.com/topic/1327500-case-cooling-dilemma/#findComment-14653787
I don't think you're replying to the right thread here.
https://linustechtips.com/topic/1327500-case-cooling-dilemma/#findComment-14653801
do see the plastic piece? usually there are 6 to eight of them. 2 at the bottom, 2 in the middle, and 2 at the top. 1 on each side.
99% of panels like this you can remove  with a good yank from the bottom of the from panel. dont be scared of it. but if you cant get it off try using some type of pliers to squeeze them as you pull the panel off.
https://linustechtips.com/topic/1327500-case-cooling-dilemma/#findComment-14654186
