Im having a computer error I have been trying to diagnose in mid use the pc will flick off and go to boot up with no error screen just get the mother board logo and windows and it keeps having the issue mid use I have cleaned the cpu out removing all dust as well as ran a drive test to see if my hardrive is bad and it is fine I don’t know if it is gpu cpu ram or power supply and I’m trying to figure out what is wrong with it.
https://linustechtips.com/topic/1327375-random-shutdown-problem/
Typically, immediate reboots like that are caused by (in this order)
Failing powersupply
Failing mobo
Failing CPU
Bad RAM (this can be tested for with MemTest)
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Failing powersupply
Failing mobo
Failing CPU
I would put bad temps near the top of that list. OP, what are load temps like?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
You are correct, totally forgot about those!
To the OP, if in doubt, you can use something like CoreTemp to see the temps of the CPU in real-time.
