Budget: 900$
is mainly a work / gaming pc
https://pcpartpicker.com/list/PJnFnL since i'm not from the us i would like to get this as lightweight as it can because is 4.25$ pound, so if you can recomend a cheap and light case that would be good, for the rest of the components if your think that i can get something better please tell me. I didn't add a GPU, i'm buying that when the things get normal, probably a 20series o 30series depending on wich one is better value when i buy it.
https://linustechtips.com/topic/1325773-my-first-build/
2 minutes ago, br_alvarado said:
Budget: 900$
made a couple small tweaks, faster ssd and cheaper mobo since the one you chose before was expensive
PCPartPicker Part List: https://pcpartpicker.com/list/JCKYCz
CPU: Intel Core i5-11500 2.7 GHz 6-Core Processor  ($217.95 @ Adorama)
Motherboard: ASRock B560M-ITX/ac Mini ITX LGA1200 Motherboard  ($151.93 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($88.99 @ Amazon)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Amazon)
Case: Phanteks EVOLV SHIFT 2 AIR Mini ITX Tower Case  ($107.98 @ Newegg)
Power Supply: Corsair SF 600 W 80+ Gold Certified Fully Modular SFX Power Supply  ($109.99 @ Newegg)
Total: $736.83
Generated by PCPartPicker 2021-04-12 11:40 EDT-0400
Where are you from?
https://linustechtips.com/topic/1325773-my-first-build/#findComment-14641157
6 minutes ago, br_alvarado said:
Budget: 900$
It's a very smart choice of components, esp given the time we're in right now. The only thing I'd change is the storage. Get a WD SN550, it's NVME, and better overall.
PS: I have little experience with cases. And the mobo, yeah, listen to what the other guy said. Didn't notice it at all. LOL.
Edited by AnirbanG007
short-sightedness
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
https://linustechtips.com/topic/1325773-my-first-build/#findComment-14641165
Total: $736.83
Where are you from?
He is gonna need a CPU cooler cuz  the 11gen is really hot
https://linustechtips.com/topic/1325773-my-first-build/#findComment-14641218
