Help on PC build
Go to solution Solved by dean_5234,
1 minute ago, Skypewizard said:
Dell Optiplex 390/790 - 2nd Gen i5 + GT 710
Specs:
-Intel i5 2400 3.1Ghz with stock fan (quad core)(upgraded Arctic thermal paste)
-GeForce GT 710 1GB Low Profile
-8GB DDR3 RAM
-500GB Hard Drive + DVD Drive
-255W Power Supply
-Windows 10 Pro installed, activated and tested.
Is it any good?(performance wise)
For gaming don't buy a GT 710, at least get like a 650 ti or 560 ti or 1030 or rx 550 or soemthing better
Specs:
-8GB DDR3 RAM
-255W Power Supply
https://linustechtips.com/topic/1325420-help-on-pc-build/
Specs:
-8GB DDR3 RAM
-255W Power Supply
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1325420-help-on-pc-build/#findComment-14638569
Specs:
-8GB DDR3 RAM
-255W Power Supply
Focus more on the power supply as well because although a dell optiplex isnt that much power 255W is still not that much.
https://linustechtips.com/topic/1325420-help-on-pc-build/#findComment-14638715
Not really necessary, as long as he's not putting a powerful GPU the dell psus are fine. I've used multiple
Big nerd.
https://linustechtips.com/topic/1325420-help-on-pc-build/#findComment-14638984
-= Topic moved to New Builds and Planning =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1325420-help-on-pc-build/#findComment-14639670
