3090 Vertical Mount
Go to solution Solved by IkeaGnome,
2 minutes ago, Renegade_326 said:
That's what I had planned but I had thought it didn't support PCIe Gen 4. Haven't had a whole lot of luck finding a cable that's PCIe 4 either so is it even possible or am I better off mounting it normally?
I missed that part. Lian Li says the cable is 200mm. (20cm if you're dumb Murican like me)
https://linkup.one/pcie-4-0-riser-cables-ultra/
Budget (including currency): $150
Country: USA
Games, programs or workloads that it will be used for: Work/Programming/Gaming
Other details: Been looking for a vertical mount for a while but I always come across conflicting information, whether it's sturdy enough or if it actually supports the mobo. This is my build I'm looking to install it in:
https://pcpartpicker.com/user/Renegade_326/saved/
CPU     AMD Ryzen 9 3950X 3.5 GHz 16-Core Processor $825.00
CPU Cooler     Noctua NH-D15 82.5 CFM CPU Cooler $90.00
Motherboard     MSI MEG X570 UNIFY ATX AM4 Motherboard $335.00
Memory     G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 Memory $360.00
Storage     Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive $180.00
Storage     Seagate Barracuda Compute 4 TB 3.5" 5400RPM Internal Hard Drive $95.00
Storage     Sabrent Rocket 4.0 2 TB M.2-2280 NVME Solid State Drive $300.00
Video Card     Asus GeForce RTX 3090 24 GB STRIX GAMING OC Video Card $2129.00
Case     Lian Li O11D XL-X ATX Full Tower Case  $225.00
Power Supply     Corsair AX 1000 W 80+ Titanium Certified Fully Modular ATX Power Supply $290.00
https://linustechtips.com/topic/1325414-3090-vertical-mount/
Country: USA
I got a lot to learn from you if you are able to buy this machine with a 150$ budget 😄
https://linustechtips.com/topic/1325414-3090-vertical-mount/#findComment-14638540
Why not use the Lian Li one? Honest question here.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1325414-3090-vertical-mount/#findComment-14638547
https://linustechtips.com/topic/1325414-3090-vertical-mount/#findComment-14638615
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1325414-3090-vertical-mount/#findComment-14638625
I am indeed a fellow dumb Murican. For some reason I never managed to find anything like that, thanks for the link!
https://linustechtips.com/topic/1325414-3090-vertical-mount/#findComment-14638644
No problem. Since the Lian Li riser is made to go in your PC and you have the budget, I'd just get that. Go to PCIE 3.0. If you happen to notice a difference, and happen to want that performance back(there's almost no drop in it) then order a 20cm cable from that link.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1325414-3090-vertical-mount/#findComment-14638649
