Help I have bottleneck
Solved by Marshmallok,
Hello friend! Don't worry, the CPU you actually have is very old for the 1050 ti as the 1050 was released in 2016/2017 around that time while the intel duo was released in 2006?i can assume you already see the problem, there is a huge bottleneck, if you have tried fixing it id like to inform you there is no use as you will actually need to upgrade the cpu,i personally use a Ryzen 5 3600 with my gpu,i recommend it because it can handle the 1050 ti and newer. Since you have an old CPU ill assume you have an old board, I recommend switching that to a b550 motherboard if it is available. And if you can spare an extra dime, maybe a 16 gb hyper x 3600 mhz memory module(2x8gb sticks)
so thats really it,good luck :).
