Need help building pc
Solved by Lil_Nugget,
Budget (including currency): 2000$ USD
Country: USA
Games, programs or workloads that it will be used for: Most AAA game light streaming and video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I already have all the peripherals and a 1440p 144hz display but 60 fps+ is just fine. btw this is the link to the monitor if you were curious https://www.amazon.com/Gigabyte-Ultra-Wide-Response-FreeSync-G34WQC-SA/dp/B08GFN64F2/ref=sr_1_18?crid=3BGF3SL83NHUB&dchild
aaaaand the link to the pc parts list that I made but have no idea if its good or not https://pcpartpicker.com/list/rm2y2V
