PC does not start anymore
Go to solution Solved by Nogrod,
I checked the RAM modules, one of the modules is broken
I was playing a game, without warning the PC just froze. My speakers made a monotonous sound. Since the PC did not respond at all, I switched off (Using the button to switch on). When I tried to turn it on again, "nothing" happened. I can't even get to the BIOS.
Only the fans (also the CPU and GPU fan) are running, the HDD is also running I think.
The "CPU_LED" on the mainboard lights up red for about 15 seconds, then the "DRAM_LED" lights up for about 17 seconds. After that the CPU_LED lights up again ...
Does anyone have an idea where the problem could be or how I can find out?
The PC is about 3,5 years old
System Specs:
Asus Z170-A Intel Z170 So.1151 Dual Channel DDR4 ATX Retail
16GB G.Skill Aegis DDR4-3000 DIMM CL16 Dual Kit
700 Watt be quiet! Pure Power 10 CM Modular 80+ Silver
Intel Core i5 7600K 4x 3.80GHz So.1151 WOF
6GB Asus GeForce GTX 1060 Advanced Aktiv PCIe 3.0 x16
a SSD and a HDD
Windows10 64 bit
https://linustechtips.com/topic/1324375-pc-does-not-start-anymore/
