Budget (including currency): 1500 canadian
Country: Canada
Games, programs or workloads that it will be used for:  video editing, light gaming, school work
https://ca.pcpartpicker.com/list/pfxdTJ
this is what i've come up with so far, is this a good setup? id be willing to hold out for a better GPU for a better price if i dont need it right away as i am aware there is a shortage, but i'm not 100% sure.
Thanks in advanced !!
https://linustechtips.com/topic/1324039-first-time-pc-build-need-advice/
geometry is hard
b550 > x570
1 hour ago, Downkey said:
yes i am 100% willing to wait for stock. thank you very much !
Well, because he is going to wait until stock of gpus, I would go Intel for the igpu.
If i were to do that would i be able to just swap out the CPU or would other things have to go? probably the motherboard too i guess.
Well I’d the advantage of waiting for all the components is that you get the 5600x
Or you can just get some cheap GPU until 3060tis come in stock
geometry is hard
b550 > x570
