So i decided to build a pc and this is what i've come up with. Any recommendations or changes that i should do?
Btw: Do i need a Fan controller and also, Pcpartpicker gives me this message: "Some AMD X570 chipset motherboards may need a BIOS update prior to using Vermeer CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions." What does this mean.
CPU:  AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor
CPU cooler:  Corsair iCUE H100i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard:  Asus TUF GAMING X570-PLUS ATX AM4 Motherboard
Memory:  Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
Storage:  Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive,  Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive
GPU:  NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card
Case:  Lian Li Lancool II Mesh ATX Mid Tower Case
PSU:  Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Xtra Fans:  Corsair iCUE SP120 RGB Pro 52 CFM 120 mm Fans 3-Pack
Monitor:  LG 27UL500-W 27.0" 3840x2160 60 Hz Monitor
https://linustechtips.com/topic/1323819-first-build-need-some-help/
