So I recently had to do a fresh install of windows on my desktop because it was freezing. I updated all drivers under the device manager, checked the motherboard website for up to date drivers, and have been troubleshooting the mic for about an hour. I haven't messed with any internals on the pc, and the case mic jack worked before I installed new windows however once installed I can only get the mic by plugging it into the motherboard. Does anybody have any idea why this would happen?
Specs:
Motherboard- Asus ROG Strix X570-E Gaming
RAM- 4x8 GB GSkill Trident Z
CPU- Ryzen 3700X 4.2 Ghz OC
GPU- Asus ROG Strix 2080TI
PSU- Thermaltake 1050W RGB
Storage- 2x 2TB M.2 drives, 1x 4TB WD blue SSD
Case- Phanteks Eclipse P400A
Headphones- Astro A10 headset with splitter cable
https://linustechtips.com/topic/1323709-help-with-mic/
9 minutes ago, Lucasgrady12 said:
Have you messed with the control panel? And also I have the same issue sometimes It works sometimes it doesn’t how I fixed the issue is just plug the mic up to the motherboard directly on the back.
Could you elaborate on "messed with"? I went into the control panel and was looking at controls and nothing was related to my issue
https://linustechtips.com/topic/1323709-help-with-mic/#findComment-14626768
8 minutes ago, Lucasgrady12 said:
Click on..... hardware and sound
I then clicked on manage audio devices and I go to input devices and see a microphone input pegged at 100%. When I swap to said microphone in discord or the windows settings it just plays static.
https://linustechtips.com/topic/1323709-help-with-mic/#findComment-14626837
R you using a voice mod or something like that  because discord is glitchy with voice mod and does it work with any thing else
https://linustechtips.com/topic/1323709-help-with-mic/#findComment-14626911
