i need some help
Go to solution Solved by DeadnightWarrior,
I wouldn't bother upgrading your PSU, a 750W 80+ GOLD should be plenty even for a high end GPU (the Ryzen 5 5600X is very efficient, things would change if you had, say, an i9 11900K IMHO).
As for mainboards, I'd choose one with a B550 chipset, there's no real reason to go X570 unless you want to pursue extreme CPU / RAM / GPU overclocking.
Graphics cards? Just wait. This is not the time to buy one, IF you can find one.
Earlier today I saw a 3090 selling on eBay for over 3100€ and the auction hadn't even ended yet! This is I-N-S-A-N-E.
Budget (including currency):  £800 GBP
Country: England
Games, programs or workloads that it will be used for:  COD, F1 , ROCKET LEAUGUE
i have a pc with a 750w power supply, amd 5 5600x and a 1650 super. i want to upgrade my graphics card and motherboard and probably psu as needed. what should i do?
https://linustechtips.com/topic/1323703-i-need-some-help/
Country: England
Two things here -
-What are your full specs (PSU, Case, mobo, SSD)
-There is a global graphics card shortage currently, and finding a GPU at a good price is extremely hard.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1323703-i-need-some-help/#findComment-14626686
MAIN PC: CPU: AMD Ryzen 5 2400G | Motherboard: Gigabyte GA-AB350-Gaming | RAM: 16Gb DDR4 Patriot Viper 4 3200 | GPU: XFX RX580 4Gb GTS | Case: Sharkoon S25-W | Storage: M.2 NVME Adata Gammix S10 128Gb + SATA SSD WD Blue 1Tb | ODD: LG GH24NSD1 | PSU: Seasonic Core GM-500 | Display: AOC I2490PXQU | Cooler: Wraith Stealth | Keyboard: Logitech K120 | Mouse: Logitech B100 | Sound: the usual integrated Realtek | OS: Windows 10 Pro 64bit
RETRO PC: CPU: AMD Athlon 64 2800+ | Motherboard: Gigabyte GA-K8VM800M | RAM: 2Gb DDR 800 | GPU: ATi Radeon 9600 Pro 128Mb | Case: Tacens Anima AC4500 | Storage: IDE WD Blue 80Gb + IDE DVD-RW drive + floppy drive | Sound: Terratec 128i ESS Solo-1 PCI | OS: Windows 98 SE + Windows XP SP3 + Linux Bionic Pup 32
HTPC: CPU: AMD Athlon 3000G | Motherboard: AsRock B450M-HDV R4.0 | RAM: 16Gb DDR4 G.Skill Aegis 3200 | Case: Aerocool CS-101 | Storage: SATA SSD Silicon Power A55 256Gb | ODD: LG blu-ray WH14NS40 | OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/1323703-i-need-some-help/#findComment-14626878
