Help needed I'm Going CrazY
Solved by MarvintheParrot,
1 minute ago, TheTrinket said:So its decided, i went with AMD 5 3600 in a Asus TUF B450M-Pro Gaming Motherboard and 16gb corsair 3200 Mhz rams.
What do you think ?
That looks great. I used to have the B450M PLUS, so its a bit different, but they have pretty much all the same features and it worked great!
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning10 -
1
2
7
5
7
play_circle_filled
Latest From ShortCircuit:
