Budget (including currency): Under 2000 CAD
Country: Canada
Games, programs or workloads that it will be used for: Want to use it for Minecraft and games similar to it. I also will use it for some programming.
Other details I will buy when I have enough money. I want to play at at least 60 fps with a few mods (In Minecraft). The peripherals are included in the price (I have none atm).
https://newegg.io/d0d16db
Feel free to ask about anything else.
Edits will go here:
Edit #1: I realized I didn't say this, but I wish to eventually upgrade the amount of monitors I have and don't want a 144hz right off the bat
https://linustechtips.com/topic/1323060-my-first-build/
CPU: Ryzen 5600x
MOBO: MPG-B550-GAMING-CARBON-WIFI(or any b550 motherboards)
GPU: GeForce GTX 1660 super or GeForce 2060 or GeForce 2060ti
RAM: G. Skill TridentZ 3600Mhz 2x8GB
PSU: RM750x 80PLUS Gold Certified Fully Modular PSU
SSD: Samsung 970 evo 1 or 2 tb
HDD: depends how many tb you want
Case: Phanteks p360a
Keyboard: get a custom one or what i personally like Royal Kludge GK61 (60% Keyboard and its hot swappable)
Mouse: G Pro Wireless or if you want to drag click Glorious Model O wireless(there is a wired option too) or Glorious Model D if you want ergonomic
Monitor: idk any good 144hz because i dont have one
https://linustechtips.com/topic/1323060-my-first-build/#findComment-14622274
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1323060-my-first-build/#findComment-14622347
7 hours ago, HairlessMonkeyBoy said:
Looking at this, I can see some places where I could cut costs. It is helpful to see a list of what someone else would suggest.
(Also, for me a used GPU isn't really an option, I live in a low population part of Canada, and don't trust mail-ins.)
https://linustechtips.com/topic/1323060-my-first-build/#findComment-14624433
Just don't cut too much on the PSU. If you want to choose something else, try to get something from tier A or B here:
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1323060-my-first-build/#findComment-14624475
