I need Help!!!
Go to solution Solved by Downkey,
2 minutes ago, PegChamp said:
ok then can you select another case because the case you put in the part list looks bad
Meshify C White
20 more but it's the best case that looks simillar to the H510
PCPartPicker Part List
Type Item Price
Case Fractal Design Meshify C ATX Mid Tower Case £82.99 @ Amazon UK
  Prices include shipping, taxes, rebates, and discounts
  Total £82.99
  Generated by PCPartPicker 2021-04-07 15:37 BST+0100
Budget (including currency): £1100 GBP
Country: United Kingdom (UK)
Games, programs or workloads that it will be used for: Call Of Duty - Cold War, Warzone, Modern Warfare..., Rainbow six siege, Battlefield 1,4 and 5, hell let loose, etc
Other details:
Hi guys, I am new to this forum and I wanted someone to help me make a £1100 GBP Gaming PC build without a GPU as I have a Nvidia RTX 3080.
This is a build which I came up with. I also have added a monitor seeing as I haven't got one.
Type Item Price
CPU AMD Ryzen 5 3600 3.6 GHz 6-Core Processor £150.00 @ Currys PC World
CPU Cooler Noctua NH-U12S chromax.black 55 CFM CPU Cooler £64.98 @ Amazon UK
Motherboard MSI B550-A PRO ATX AM4 Motherboard £129.97 @ Amazon UK
Memory Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory £89.98 @ Amazon UK
Storage Samsung 970 Evo Plus 250 GB M.2-2280 NVME Solid State Drive £55.49 @ Amazon UK
Storage Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive £43.94 @ Amazon UK
Case NZXT H510 ATX Mid Tower Case £74.98 @ Amazon UK
Power Supply Gigabyte P GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply £74.99 @ CCL Computers
Case Fan ARCTIC P14 PST 72.8 CFM 140 mm Fan £9.69 @ Overclockers.co.uk
Monitor LG 27GL850-B 27.0" 2560x1440 144 Hz Monitor £379.00 @ Currys PC World
  Total £1082.71
  Generated by PCPartPicker 2021-04-06 23:20 BST+0100
https://linustechtips.com/topic/1323055-i-need-help/
1 minute ago, PegChamp said:
Could you make a build with the original case I put in the build I made
The orignal case you put is pretty bad. Has little airflow and is bad value. Your components will run very hot, especially with a 3080.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1323055-i-need-help/#findComment-14622810
Meshify C White
Type Item Price
  Total £82.99
geometry is hard
b550 > x570
https://linustechtips.com/topic/1323055-i-need-help/#findComment-14622830
