so im gonna build a pc for my gf these are the specs that are planned
cpu a ryzen 5 3600
mobo MSI B450I GAMING PLUS AC
ram corsair vengance lpx 2 x 8 gb 3200mhz
gpu probaly a 1070 or something im waiting for the prices to come down
ssd kingston a2000 500gb
cooler the stock amd cooler en eventually a 240mm aio
case nzxt h210 black + red
psu corsair cx650f
and some red + black cable extensions
thanks for the feedback if you give some😃
https://linustechtips.com/topic/1322743-pc-build-for-gf/
cpu a ryzen 5 3600
psu corsair cx650f
Is she going to overclock? If not, the 240mm aio is probably not necesary.
https://linustechtips.com/topic/1322743-pc-build-for-gf/#findComment-14620330
cpu a ryzen 5 3600
psu corsair cx650f
Well, this is definitely the one pc in your life that you don't want to mess up if you are hoping to make this a long term relationship. 😉
https://linustechtips.com/topic/1322743-pc-build-for-gf/#findComment-14620349
3 minutes ago, curiousmind34 said:
lol probably not the best use of performance per dollar but if its for the looks cant argue
i might just get a wraith prism they are only 20 euros so and it has alot of rgb and ill just get some good and cheap rgb fans the pc
https://linustechtips.com/topic/1322743-pc-build-for-gf/#findComment-14620351
well she is gonna build it hirself ill ofc help hir with it but even tho im young thats why my name is kes2006 still gotta treat your girl the best and i also hope it will be a long term relationship
https://linustechtips.com/topic/1322743-pc-build-for-gf/#findComment-14620361
good luck with the relationship!
and if you plug in one connector backwards it’s all over, so don’t screw up. /s
https://linustechtips.com/topic/1322743-pc-build-for-gf/#findComment-14620371
4 minutes ago, JohnDeereBro said:
Yeah, good luck. 👍
both of you thanks for the good lucks and advise
https://linustechtips.com/topic/1322743-pc-build-for-gf/#findComment-14620383
