help plan my build please
Go to solution Solved by Downkey,
Original PSU mentioned was a fire hazard. WIth some cost cutting, and getting rid of the overkill case, you can it a 5600x. You can also put a 3700x if you care more about productivity
Budget (including currency): about £1250 (GBP)
Country: United Kingdom
Games, programs or workloads that it will be used for: no mans sky, call of duty, unity, unreal, blender
i have about £100 above the budget if needed
preferably i would like to build the PC in either October or September as i want to take it to university
i had a few plans around the GPU. i would like a 30 series card preferably and i have over budgeted the 3060 TI which is the card i plan and would like because of the situation to be £540, im unsure if i should get a CPU with onboard graphics and wait for the stock to come back but this would mean no games probably or i can try get lucky with a stock checker to get a 3060 TI
i also currently have a laptop with an I7 10750 and GTX 1660 TI which i can use for the mean time if waiting for a GPU is a better idea but i would preferably like the PC for september
WIFI and Bluetooth are necessary for me and im looking at either a 3060 TI or 3070
the main needs are the ability to play games, and make games in unity and unreal and make assets for games in blender
PCPartPicker Part List: https://uk.pcpartpicker.com/list/wpjrsX
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£150.00 @ Currys PC World)
Motherboard: MSI X470 GAMING PLUS MAX ATX AM4 Motherboard  (£79.98 @ CCL Computers)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  (£99.98 @ Amazon UK)
Storage: ADATA XPG SX8200 Pro 512 GB M.2-2280 NVME Solid State Drive  (£62.99 @ Box Limited)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (£43.96 @ Amazon UK)
Video Card: GeForce RTX 3060 Ti  Video Card  (£540.00)
Case: Thermaltake View 51 ARGB Edition ATX Full Tower Case  (£187.74 @ Ebuyer)
Power Supply: Gigabyte P GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£74.99 @ CCL Computers)
Wireless Network Adapter: Ziyituod ZYT-7265 PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter  (£22.90 @ Amazon UK)
Total: £1262.54
Generated by PCPartPicker 2021-04-06 19:51 BST+0100
https://linustechtips.com/topic/1322619-help-plan-my-build-please/
geometry is hard
b550 > x570
that's great thank you
