Budget (including currency): $800-$900 USD
Country: United States
Games, programs or workloads that it will be used for: Minecraft, COD, Warzone, Sea of Thieves, Apex
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): No peripherals needed but monitor needes to be included at least 1080p. GPU price included at MSRP.
https://linustechtips.com/topic/1322553-pc-build-advice/
2 minutes ago, Noah Johnson said:
You probably just need to find a laptop with at least a Ryzen 5 4600H, and like an RTX 2060, might be at the max of the budget, but it gives you DLSS over like a 1660ti
still can't really buy a lot of PC parts or their pricing is expensive.
https://linustechtips.com/topic/1322553-pc-build-advice/#findComment-14619219
