Pc won't boot. Need advice.
Go to solution Solved by Faris14,
1 hour ago, SpiderMan said:
That's very strange for the motherboard to working only with 3 slots. Definitely return it as you don't know what will happen in the future.
Slots number :1,2,3 do not work at all only slot 4 works, and the ethernet is broken as well. Honestly no clue how so much can be wrong with a new motherboard and I wore esd protection. I will just go return it tomorrow and request a refund or to give me another board. Thanks for the help.
Edit: forgot t mention that the 3rd slot does work but only if its the only populated slot and it takes around 5 to 7 minutes for it to start working.
So when I want to boot, I get no output, I connected the motherboard speaker. Then I get if I have my ram in dual channel mode continous long beeps, but when I only put 1 ram stick in I get 5 short beeps which is rze error code for cpu. I checked the socket there are no bent pins or anything tried reseding ram multiple times and the cpu as well. I tried with both sticks and if I only put 1 ram stick in I get cpu error code but when I put both in its memory error code. What could it be? Should I just returny my motherboard tomorrow? Gigabyte b460m ds3h v2(h470 socket), crucial balistix 16 gb (8gb ×2) ddr4 3000 Mhz, intel i3-10100f.
https://linustechtips.com/topic/1321889-pc-wont-boot-need-advice/
<-- Moved to Troubleshooting -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Have you tried to clear CMOS or use another RAM kit to rule out the RAM kit is not defective? Try different RAM and if it still persists, the motherboard can be defective. Also, be sure the RAM is fully seated where you hear two audible clicks when pushing down on the RAM sticks.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Im on my way to my friend to try a other ram kit.Also my gpu sometimes will not turn on when the pc start to boot.And i will update the BIOS and clear the CMOS later
So we tried different ram and graphics and I still get memory beep and tried my ram in different pc and booted up no problem
Then I'd suspect the motherboard is defective.
1 minute ago, Faris14 said:
Yep.... nothing more to try cleared cmos as well
I'd return the motherboard and buy another one or get a different model. Don't bother with RMA if it's still within the retailer's return window. Just tell them that the motherboard is not working.
I bought it like 4 days ago so definetly returning it. By the way looks like slots 1 2 3 are dead and only slot 4 works. It just started working randomly  five minutes ago
Edited by Faris14
