VG279QM Issues
Solved by Nathanpete,
Just now, oitsume said:The thing with HDMI is that I no longer have the option to overclock it to 280hz
My theory: The panel is probably overclockable to 280 Hz, but HDMI 2.0 doesn't actually have enough bandwidth for 1080p280. (IDK if this is true, I don't have that much time to look up the amount of bandwidth a 1080p280 signal uses).
Kind of a scam, kind of not. If you lower the resolution to something like 9##p or 1000p, can you OC then? If yes, then Asus didn't make a 280 Hz monitor, with 1080p280 connectors (like HDMI 2.1, which the 3070 does support), they made a 280Hz IPS panel, and made a monitor out of it.
