So I recently downloaded Battlefield 3, I finished Arkam Origins, which I loved and which I believe to be a more intensive game, and now, from time to time,  my Graphics card (Gigabyte GTX 780) suddenly decides to ramp up as much as possible. It sounds like a hairdryer! I downloaded MSI afterburner and set my own fan curve, for a while everything was going normal, I turned on Kombustor and a couple seconds after that the fans went crazy again, however in Afterburner the GPU temps were at 46 degrees Celsius and, more importantly, the fans speed was said to be at minimal RPM, probably even 0%! Can anyone help?
https://linustechtips.com/topic/132100-gpu-sudden-noise/
Keep afterburner running in the background.  I've noticed if I exit out of it the fan curve decides to turn itself off.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/132100-gpu-sudden-noise/#findComment-1757926
