Hello, I have a Asus Sabertooth Z77, my problem is that my pc always boots when I press a key of the keyboard, I have updated my Bios to version 1908, and I can't find the option to disable the legacy boot. Is there anyone who has the same version of Bios (1908) who can help me resolve this issue?  Thanks guys.
Case- Cooler Master Haf X
CPU- i7 2600k @ 4.4
CPU cooler- Nzxt Kraken x40 in push pull with Noctua NF-A14 fans
MB- Asus Sabethooth z77
Memory- 16gb Corsair Vengance @ 1866mgz
SSD- Vertex 4 256gb
Second Storage- WD Caviar Black 2tb
Power Supply- OCZ ZX 850w
GPU- Asus Strix Geforce 980
Sound Card- Asus Xonar DX
Opt. Drive- Pioneer Blu-Ray Burner
Monitor- Asus ROG Swift
Windows 7
https://linustechtips.com/topic/13205-asus-sabertooth-z77-help/
I have the same motherboard, and I believe I've seen the option to do a legacy boot. Have you tried pressing F7 to go into the advanced menu?
I'll try that and I'll get back to you.  Do you have the latest update for the Bios (1908).
CPU- i7 2600k @ 4.4
SSD- Vertex 4 256gb
Windows 7
https://linustechtips.com/topic/13205-asus-sabertooth-z77-help/#findComment-141398
