Hey, im looking to upgrade my pc, because I believe my cpu is bottlenecking my build and I'm looking for some reccomendations. My Build is this one:
CPU: Intel I3-9100F
GPU: GTX 1650 Super
Memory: 2X4 GB
PSU: 450W
I was thinking of maybe investing in an I9-9900K since its the best cpu the motherboard, although im not sure if I should buy a Noctua fan, and I'm not sure with this change if i would have to upgrade my psu as well. Any tips and comments are greatly appreciate it. Thanks for helping a noob like me.
https://linustechtips.com/topic/1319919-help-upgrading-my-pc/
CPU: Intel I3-9100F
GPU: GTX 1650 Super
Memory: 2X4 GB
PSU: 450W
What are your full specs? Please include your specific PSU, Case, RAM speed, etc
geometry is hard
b550 > x570
https://linustechtips.com/topic/1319919-help-upgrading-my-pc/#findComment-14597760
CPU: Intel I3-9100F
GPU: GTX 1650 Super
Memory: 2X4 GB
PSU: 450W
Personally I'd upgrade to 16GB of ram first. Also the 9900K and 1650S are totally unmatched. You may want to look for something like a 9400(f) or 9600K(f)
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1319919-help-upgrading-my-pc/#findComment-14597768
CPU: Intel I3-9100F
Mobo: MSI B360m Bazooka mATX LGA 1151
Memory: Patriot Viper 2X4 gb
Storage: Patriot Burst 960GB SSD
GPU: Zotag GTX 1650 Super 4GB Gaming
Case: MATTREXX 30 mATX mini tower case
PSU: Corsair VS 450W 80+ certified
https://linustechtips.com/topic/1319919-help-upgrading-my-pc/#findComment-14597770
The thing is that the reason I want to upgrade is because I play many FPS games, and since I got my second monitor, the CPU has been running at full capacity after a while in some games, and spontaneously freezes for a second, which is kind of frustrating in FPS games in the middle of a match which makes me die. The temperatures seem fine, and the RAM doesn't really seem to max out either, that's why i thought the CPU was the one bottlenecking the build and causing those issues.
https://linustechtips.com/topic/1319919-help-upgrading-my-pc/#findComment-14597776
Honestly, if you are going with a 9900k, you would need ALOT of upgrades. A cooler, new mobo, new PSU. Judging by what your doing, honestly get a 5600x, or just get something like a 9600K. Don’t waste your money on a 9900k.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1319919-help-upgrading-my-pc/#findComment-14597784
