Help deciding ram upgrade path.
26 minutes ago, BillyGoat1776 said:Personally, I do not think there would be a tangible difference and the other two poster's are not wrong...I doubled down because I didn't want anyone thinking I was giving bad advice or simply talking out of my a*s
Good luck!
I've done some more digging and come to the conclusion that best case scenario i might get 1-2 fps extra. If it support quad channel over dual.
Only difference i more than likely would notice is the latency, which there would also be 1-2% increase. Assuming both have the same CAL, which one can play around woth in bios on your owk if i remember.
So i'll be going for 4x8 for the small gamble of maybe an extra fps in games.
At the point where i'll be needing 64GB ram i'll probably be building a new PC all together or have the cash flow to just buy it without a worry.
Thank you all for the answers and info, it got me to look in the right direction for my own digging.
Case closed~
