I've bought some pc parts for my friend and I'm building them a computer.
The parts are a:
Ryzen 5 5600x
Asrock B450 Pro4
GTX 1080
750W PSU
2TB HDD
120GB SSD
16GB of 3200 RAM
And now for the past 2 days I've been trying to troubleshoot but i didn't get it to work.
The fans spin up and the gpu sends a signal to my monitor for like a short second, but i see no start up screen or anything. My keyboard doesn't light up either. It just runs for like 30seconds then it turns off and restarts.
I've checked and all the parts seem to be fine. It doesn't beep or do anything it just gets into a bootloop.
If anyone can help it would be much appreciated thank you.
https://linustechtips.com/topic/1318881-my-pc-wont-post/
The parts are a:
Ryzen 5 5600x
Asrock B450 Pro4
GTX 1080
750W PSU
2TB HDD
120GB SSD
16GB of 3200 RAM
Is the BIOS on the motherboard updated for 5th gen?
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589760
Likely a BIOS update is needed. The old B450s don't come with a BIOS compatible with the 5600X. You may need to borrow a really cheap like Ryzen 3 or even Athalon in order to update unless your motherboard supports BIOS flashing with nothing but the mobo and PSU.
Like I know MSI boards have that feature, because it just saved my ass after the MSI Dragon Center fucked my ass. Just not sure about ASRock.
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589775
I'm not sure I've got the new bios on a usb but i don't have a last gen cpu to get in the bios. Idk how to update it without a cpu
Find your mobo's manual and see the steps for updating the BIOS via USB. If there is a section explaining how to do it just by plugging in the motherboard to the PSU, then plugging in a USB stick into a certain port, then pressing a button, follow that section. If there isn't, well then you may need to go asking around to borrow a really cheap AM4 processor for a couple hours.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589783
This is what I found in the lil book but I'm not sure how to do it because I've also read that i can brick my board if i do it wrong.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589791
The whole point of a way to flash a BIOS with no other components installed is to revive a bricked board. I just tried to update my BIOS from within Windows by using the MSI Dragon Center. But that app is a piece of shit and when windows shut down my mobo was bricked because the update failed. Lucky for me, after watching a few youtube guides because the ones from MSI's channels were missing some important info, I was able to successfully flash the newest BIOS on like my 4th attempt.
The feature is designed to give you a huge amount of attempts (until the BIOS chips wear out from too many writes, but that is A LOT) to revive a bricked BIOS.
Also the picture doesn't offer anything useful. Look through the table of contents for a section on updating the BIOS and flip to that page and take a high res photo of the whole page. Or if you can just link the PDF of the manual that ASRock provides on their product page and tell us which page to go to, that would be better.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589814
With a budget board like yours I think you will need a older CPU to update the BIOS. See if you can get an older one or like a loaned one. If you have to buy one go for a cheap AM4 one thats on the motherboard page's CPU Support List. Maybe you can sell it after to make back some money.
Big nerd.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589820
https://www.asrock.com/mb/AMD/B450 Pro4/index.de.asp#Overview
This is the product website. I've went through the manual but didn't find anything about updating the bios.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589833
I'll take a look online to see how cheap i can get one. If no other methods work thank you
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589837
Oh one last question
I have a Ryzen 7 3800x in my personal pc if i take that one it should work right?
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14589875
Yea it should
Big nerd.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14590087
Weird. As I am not a tech support expert IDK what else it is, perhaps something is dead or there is another problem. Hopefully the other members of the forum can help us lol
Big nerd.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14590258
Hopefully because now I'm out of options but thank you
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14590278
yea no problem i did what i could lol
Big nerd.
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14590412
3 hours ago, TheRealG02 said:
I have updated the bios now but after placing in the 5600x again this has happend
It looks like the BIOS updated successfully, and the Ryzen 5600X is being recognized.
You are also able to make it into the UEFI BIOS menu as well.
Your problem now appears to be a GPU problem now.
Those red lines across the screen could be:
  • Faulty video out port
  • Faulty / loose video cable
  • Faulty / dying GPU
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1318881-my-pc-wont-post/#findComment-14590845
