5 hours ago, Theo_JG said:
So I have a 360mm rad but it says my case only supports 240mm rad or 3 120mm fans
so will I be able to fit my 360mm rad and just put 2 fans on it or will that not works
if your case will support 3 120mm fans then more than likely it will support the 360 rad but what you are saying is confuising and missing more info we need to give you a better answer. you say that the case will support a 240mm rad or 3 120mm fans. so will it support 3 fans only in the entire case?
what is the case you have now?
https://linustechtips.com/topic/1317771-will-may-rad-fit/#findComment-14581659
Antec nx300
https://linustechtips.com/topic/1317771-will-may-rad-fit/#findComment-14582907
4 hours ago, tkitch said:
You *might* get a 360 rad in there, but it doesn't look like there's much space in front, so it's really iffy.
It *might* work with 2 fans, but no way to know.
NX300 BLACK (antec.com)
your case says it only supports a 240mm rad in the front probably because a 360mm interferes with the PSU shroud and the GPU is bigger than 320mm.
this case as it appears is bad for airflow anyway as its mostly solid panels.
https://linustechtips.com/topic/1317771-will-may-rad-fit/#findComment-14584145
