Okay so, I've got 16GB DDR3 clocked at 1333mhz. (MOBO(ms-7728 ver-2) doesnt support 1600mhz)
i have a gtx 660 2GB GDDR5 clocked at 1201mhz core and 3150mhz memory (small overclock)
and an i7-2600 without overclock.
My problem is, whenever i play gta 5, or hitman 2, or just do something ram consuming. my system closes the applications when i hit 10.5GB's usage, thats not even 70% of the physical memory and this is especially weird since my laptop with 4GB DDR3, celeron n3060 and hd graphics 400 (not 4000 i actually mean 400) can go to 95% usage before doing that. They both dont have any virtual memory because i hate it for personal reasons. Can anyone tell me how i can fix this? because not being able to use 30% of my physical memory (about 4.3GBs) is kinda frustrating when multitasking
Thanks in advance!
https://linustechtips.com/topic/1317278-memory-not-going-over-66-usage/
Why you would disable virtual memory is beyond me? Its there to stop exactly this happening.
In task manager how much of your 16gb is actually available? Any motherboard + CPU that has onboard graphics will allocate some system memory to use as VRAM for the IGPU, regardless of if you're running a dedicated GPU. Its possible in your BIOS the amount set aside for the IGPU is upwards of 4GB
I don't have an IGPU, there are no settings for graphics or vga in bios, i disable virtual memory because its really sluggish and frustratingly laggy when gaming and in task manager all of it is availableimage.thumb.png.a92ec95edd5c3930aba995b89685387b.pngimage.thumb.png.d3e96212acda2dc5bd9e85fd5c31c5be.png
can you check your memory for any errors, like memory diagnostic?
I can't answer everything but I will try my best to give solutions depending on what I experienced in troubleshooting
understand my mistakes and please correct me too 🙂.
