Okay, so i bought a gtx 1650 super like 4 months ago. It was running at max 99% usage. But lately both my cpu and gpu usage got high. Cpu running at 100% sometimes.Gpu running at 100% on any game with highest graphics on. Which is most weird is that my gpu runs at 100% usage on World Of Warcraft, there's when i knew something was wrong. Please help me i am so tired of having issues everytime. Oh yeah, Fps feels lower than before, also when looking around fast fps drops by 10-20 fps.
Gpu = Gtx 1650 super
Cpu = i3 9100f.
Ssd = Samsung 870 evo.
motherboard = z390-a-pro.
Ram = hyperx 4x2.
Power supply = Hyper M 500W.
Would be awesome to get some help.
https://linustechtips.com/topic/1317137-gpu-running-at-100-not-normal/
@Pikatchu I.ll send them to you as fast as possible. Google chrome taking up 5,5 to 7.9% Msi afterburner 1.8 max. Google chrome taking up 1.6 max
runtime process for the client server seems to take up 25% of my gpu sometimes.
@Avanta8
Overall this PC is performing below expectations (38th percentile). This means that out of 100 PCs with exactly the same components, 62 performed better. The overall PC percentile is the average of each of its individual components. Use the charts in the benchmark sections of this report to identify problem areas.
Processor With a good single core score, this CPU can easily handle the majority of general computing tasks. Additionally this processor can handle very light workstation, and even some very light server workloads. Finally, with a gaming score of 77%, this CPU's suitability for 3D gaming is good.
Boot Drive 115% is an exceptional SSD score. This drive is suitable for heavy workstation use, it will facilitate fast boots, responsive applications and allow for fast transfers of multi-gigabyte files.
Memory 8GB is enough RAM to run any version of Windows and it's sufficient for the vast majority of games. 8GB is also enough for moderate file and system caches which result in a very responsive system.
OS Version Windows 10 is the most recent version of Windows, and the best to date in our opinion.
2 minutes ago, Andy that has problems said:
@Avanta8 I also think that it failed. It said something like that when i was downloading it. This gpu was overclocked when i got it. Gtx 1650 super tuf oc
So can you tell me what it says in the benchmark log? If you've already closed it, then just run it again.
And have you overclocked the GPU yourself?
@Avanta8 INFO: Current software signature: [829e1ae4c8b7472bb85bd7f7faffbf50]
INFO: Checking for updates on UserBenchmark.com
INFO: Version check passed
INFO: Benchmark engine running
INFO: Checking OS support
INFO: Checking CPU power status
INFO: Gathering Device Info
INFO: Starting CPU tests
INFO: Launching CPU benchmark suite
INFO: Running 1 core CPU benchmark ...
INFO: 1Core Int total throughput: 115.7
INFO: 1Core Float total throughput: 127.7
INFO: 1Core Mixed total throughput: 118.8
INFO: Running 2 core CPU benchmark ...
INFO: 2Core Int total throughput: 223.5
INFO: 2Core Float total throughput: 253.6
INFO: 2Core Mixed total throughput: 230.6
INFO: Running 4 core CPU benchmark ...
INFO: 4Core Int total throughput: 414.5
INFO: 4Core Float total throughput: 474
INFO: 4Core Mixed total throughput: 427.5
INFO: Running 8 core CPU benchmark ...
INFO: 8Core Int total throughput: 414.9
INFO: 8Core Float total throughput: 470.3
INFO: 8Core Mixed total throughput: 440
INFO: Running 64 core CPU benchmark ...
INFO: 64Core Int total throughput: 407.3
INFO: 64Core Float total throughput: 447
INFO: 64Core Mixed total throughput: 419.5
INFO: Exiting CPU benchmark suite
INFO: Completed CPU benchmarks
INFO: Starting RAM tests
INFO: Launching RAM benchmark suite
INFO: Checking RAM configuration
INFO: Running 1 core RAM benchmark ...
INFO: 1Core Read total throughput: 16.2
INFO: 1Core Write total throughput: 31.6
INFO: 1Core Mixed total throughput: 23.5
INFO: Running 2 core RAM benchmark ...
INFO: 2Core Read total throughput: 24
INFO: 2Core Write total throughput: 33.1
INFO: 2Core Mixed total throughput: 26.7
INFO: Running 16 core RAM benchmark ...
INFO: 16Core Read total throughput: 29.1
INFO: 16Core Write total throughput: 33.1
INFO: 16Core Mixed total throughput: 26.2
INFO: Running system latency tests ...
INFO: 1KB memory latency: 1.08 ns
INFO: 2KB memory latency: 1.04 ns
INFO: 4KB memory latency: 1.08 ns
INFO: 8KB memory latency: 1.06 ns
INFO: 16KB memory latency: 1.05 ns
INFO: 32KB memory latency: 1.06 ns
INFO: 64KB memory latency: 1.96 ns
INFO: 128KB memory latency: 2.42 ns
INFO: 256KB memory latency: 2.88 ns
INFO: 512KB memory latency: 7.34 ns
INFO: 1MB memory latency: 9.56 ns
INFO: 2MB memory latency: 11.26 ns
INFO: 4MB memory latency: 16.5 ns
INFO: 8MB memory latency: 40.18 ns
INFO: 16MB memory latency: 53.21 ns
INFO: 32MB memory latency: 58.81 ns
INFO: 64MB memory latency: 59.49 ns
INFO: 128MB memory latency: 62.24 ns
INFO: 256MB memory latency: 64.38 ns
INFO: Exiting RAM benchmark suite
INFO: Completed RAM benchmarks
INFO: Gathering drive info
INFO: Launching Core drive benchmarks on C:
INFO: C: sequentialWrite 471.8 MB/s
INFO: C: sequentialRead 507.1 MB/s
INFO: C: sequentialMixed 423.4 MB/s
INFO: C: 4kRead 43.9 MB/s
INFO: C: 4kWrite 89.9 MB/s
INFO: C: 4kMixed 56 MB/s
INFO: C: 4k64thrRead 376 MB/s
INFO: C: 4k64thrWrite 333.9 MB/s
INFO: C: 4k64thrMixed 353.9 MB/s
INFO: Launching sustained write bench on C:
INFO: Checking GPU configuration
INFO: Launching SustainedWrite drive benchmarks on C:
INFO: Found 1 graphics card(s) and 1 active display(s)
INFO: Starting GPU Benchmarks
INFO: Launching NGPU detection
INFO: NGPU Name: GeForce GTX 1650 SUPER
INFO: NGPU Driver: 461.92
INFO: NGPU Bios: 90.16.46.00.60
INFO: NGPU Total RAM MB: 4096
INFO: NGPU Max C MHz: 2160
INFO: NGPU Max M MHz: 3000
INFO: Launching AGPU detection
INFO: Completed GPUStats successfully
INFO: Bench NVIDIA GeForce GTX 1650 SUPER @(ZOWIE XL LCD) on display(1) = main
ERROR: Plane GPU benchmark failed, aborting further tests on this GPU
INFO: Completed GPU benchmarks
INFO: Waiting for sustained writes ... 56
INFO: Waiting for sustained writes ... 55
INFO: Waiting for sustained writes ... 54
