9 minutes ago, EKWorks said:
Thing is I'm not sure how to go about that. I only got my iPhone recently, had an android prior. Sorta confusing
Hold down your win key, press x, in that menu press device manager.
IF the iPhone is detected but not installed, right click on it and update drivers.
It’s there under portable devices but cannot update any drivers since no internet access
I would try to download iTunes on a PC with internet and transfer it over on a USB then. You're going to need either net or iTunes to install the drivers.
Quite literally done that prior to your reply. Works well now. Thanks!
