Budget (including currency): ~400e
Country: Serbia
Games, programs or workloads that it will be used for: PUBG, CS:GO, Rocket League
Other details ryzen5 2600x, evga gtx 1070 ac3, gigabyte B450M S2H, CHIEFTEC ELEMENT 700W, some 16GB(8x2) 2666mhz, Kingston SSD SA400 240GB 144hz zowie benq monitor
I want to upgrade my processor to 5600x and on mobo website 13 days ago update popped that will support 5000 series ryzen, i was wondering should i upgrade my MOBO aswell cause i plan to use it only for gaming and i want to buy M.2(Adata 500GB Swordfish 500G-C) and maybe faster RAM (2x8 3200Mhz) instead of MOBO. I keep hearing from some friends that i have to get a better Mobo first.  Thanks for reply. Cheers!
https://linustechtips.com/topic/1316278-build-question/
I'm confused on what currency you use, so I'm just going to state parts that I will recommend.
The 5600X is a good choice, although if you pair it up with a B550 board, you'll need to update the BIOS.
Your current motherboard was a good choice for the 2600, but it won't suffice for the 5600X. You can get a B550-A Pro from MSI.
As for RAM, 2666MHz will choke Ryzen. Consider getting a Crucial Ballistix 3600MHz, but if you don't have the budget then a 3200MHz kit will do.
→  Kindly quote or mention me if you would like a reply back.
<famous quote>
https://linustechtips.com/topic/1316278-build-question/#findComment-14569675
