I was playing and my mouse went flat had the red light but still had lights on the side too so I plugged it in and it looked like it was charging but the side lites went off and it was a full red srolll wheel no flashing indication it’s not charging I think, then just all the lights turned off and I tried reconnecting it and I’m getting no lights at all and it’s not picking it up and it’s not working at all I’m mot sure what happened but it’s just not working I tried another cable with same result
https://linustechtips.com/topic/1315807-model-o-wiress-issue/
7 hours ago, hysel said:
Is this a wireless mouse, if so, have you tried to replace the chargeable battery?
It’s a glorious model o wireless and it’s brand mew have only had it just over a week all was well I was playing with it then I plugged it in kept playing and after about a min it started to cut out and what not I know if fully died but I’m wondering if me playing with the cable in maybe damaged the port or something
https://linustechtips.com/topic/1315807-model-o-wiress-issue/#findComment-14566480
Could be, try to return it
https://linustechtips.com/topic/1315807-model-o-wiress-issue/#findComment-14566491
1 minute ago, hysel said:
I am a low sense player and move my mouse around a lot I’m wondering if I have slightly pulled and damaged the port playing with it plugged in, I think I’ll have to do that
https://linustechtips.com/topic/1315807-model-o-wiress-issue/#findComment-14566499
