Shattered PC Side Panel
Go to solution Solved by Avanta8,
1 minute ago, Zypeth said:
No no, the side panel is completely gone. I didn't state that before. It's all in the trash. Broke into a million pieces.
Ah, that sucks. The pc will be absolutely fine though.
1 minute ago, Avanta8 said:
Glass is not conductive, so you can't keep using it and don't need to worry about it causing a short somewhere. Is it completely shattered, or is it just cracked, but still on there?
