So I got a new pc case. It's a Corsair Carbide Spec Delta.
And so, I moved my pc from the old case to the new one and everything went smoothly until I tried to power it on. It would turn on for a couple of seconds and the fans would start spinning and then
after a bit everything would turn off. After some digging the problem was coming from the case Power switch cable on the fpanel on the motherboard. when i disconnected it and turned on the pc
by touching the power socket using a screw driver, the pc booted normally and everything worked again. But now it's a pain to keep using a screw driver to turn on the pc everytime.
Is there a solution to this?
P.S I did check my power switch connection and it was 100% correct. I saw the manual and YT tutorial.
https://linustechtips.com/topic/1314858-pc-power-switch-turning-off-pc/
