Hi, I have recently bought a new gaming pc. In CS:GO I usually get around 170 fps in the highest settings and I have a 60 hertz monitor. But I experience screen tearing in CS:GO. How do I fix this with te least amount of input lag? I have AMD radeon software, so that could potentially solve the problem. Thank you in advance!
https://linustechtips.com/topic/1314674-screen-tearing-help/
3 minutes ago, King of Memes said:
u could try capping ur fps. if u cap it to 60fps, that might be able to eliminate screen tearing. i always cap my fps in games so im not overworking my pc
Doesn’t that increase input lag or am I wrong? I would like to play competitive!
https://linustechtips.com/topic/1314674-screen-tearing-help/#findComment-14555906
well, it rly isnt that much. Here, ill show u how it works. this is how often frames are displayed on monitors:
60hz - every 16.67 ms
75hz - 13.33 ms
144hz - 6.94 ms
240hz - 4.17 ms
360hz - 2.78 ms
And for about 170 fps, which is what ur getting, new frames are being delivered around every 5.88 ms. But since ur only seeing frames every 16.67 ms, it wont rly make much of a difference. And the difference that it will make is much better IMO than screen tearing.
I hope this helped you understand it 🙂 i dont think capping ur fps will make a huge difference. And I've heard it eliminates screen tearing.
my signiture was cool, but its a lie now
https://linustechtips.com/topic/1314674-screen-tearing-help/#findComment-14555960
I don't know if this would work, but I wonder if limiting your framerate to 120 FPS (exactly double your refresh rate) would reduce or stop the tearing, since the refresh cycles would match up to frames at a clean 2:1. (Or maybe that only means the tear will always be dead-center on screen... 😛) Just something to try, I guess.
To my knowledge there isn't really a "fix" though. If your framerate exceeds your monitor's refresh rate, you'll often see tearing.
https://linustechtips.com/topic/1314674-screen-tearing-help/#findComment-14556229
If you want to play competitive buy a real monitor. I’m not trying to sound like a jerk but if you only have a 60 Hz one now the input lag is probably bad on it to
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1314674-screen-tearing-help/#findComment-14556240
