Q-Flash Plus allows you to update the BIOS when your system is off (S5 shutdown state). Then you can save the latest BIOS on a thumb drive and plug it into the dedicated port, and then you can now flash the BIOS automatically by simply pressing the Q-Flash Plus button.
Yes, you have to remove your gpu, cpu and ram.
https://linustechtips.com/topic/1312928-how-does-qflash-work/#findComment-14540652
