Sometimes when I open up my windows search bar, a black box appears on top of it. Tried resetting windows search, rebuilding the search index, running the troubleshooter and System file checker but nothing works. It doesnt happen when I power up my lap and use it for the first time, but after a while it comes up. Restarting windows explorer gets rid of the problem temporarily but need a permanent solution!
https://linustechtips.com/topic/1312868-need-help/
  • 2 weeks later...
On 3/9/2021 at 3:25 PM, ImethG said:
Here you go..It goes away when I click on it if that helps.
That could be anything from a driver error to a windows error I'm afraid.
If you REALLY want it to go away, I'd suggest reinstalling windows. (remember backups)
Is windows fully updated?
https://linustechtips.com/topic/1312868-need-help/#findComment-14572695
  • 3 weeks later...
