Hello guys so i need help withmy build i have decided all the parts except the psu (power supply) i want you guys to tell how much WATT i actually need for my system the details are bellow:
Asrock phantom gaming 4 B365m motherboard
Nvidia GeForce GT 710 2gb and a old gigabyte graphics card that i dont recognize
hyper fury rgb 16gb ddr4-2666mhz 2 modules Ram
Crucial P1 SSD 1 TB M.2 NVMe
Arctic Freezer 34 eSports Duo White CPU cooler
Deepcool Matrexx 55 ADD-RGB Black PC case
6 SilentiumPC Corona HP RGB PC case fans
And now i dont know what psu i should buy ..... please help
https://linustechtips.com/topic/1312565-help-please/
What processor?
I would suggest a 500W 80 plus gold or better PSU.
If you plan on upgrading the graphics card later, make sure to get a power supply that can handle that one as well.
https://linustechtips.com/topic/1312565-help-please/#findComment-14538001
1 hour ago, Applefreak said:
What processor?
Corsair CV Series CV650 650W Full Wired 80 Plus Bronze
is this one ok?
https://linustechtips.com/topic/1312565-help-please/#findComment-14538194
is this one ok?
It would be ok but I would recommend getting a 80+ gold rated or better power supply instead. Also the CV line is super budget oriented one. For longevity and stability get a higher tier one. If you won't be upgrading that graphics card anytime soon, you can get away with less power than that just fine.
https://linustechtips.com/topic/1312565-help-please/#findComment-14538202
ok thanks
https://linustechtips.com/topic/1312565-help-please/#findComment-14538205
Be Quiet Pure Power 11 500W Full Wired 80 Plus Gold
this would be ok ?
https://linustechtips.com/topic/1312565-help-please/#findComment-14538210
