Ok so i have a GeForce GTX 1660 Super and AMD Ryzen 5 3600 with a 80+ Bronze 600W and a B450 TOMAHAWK MAX II
I'm planning to upgrade to a 3060 but I'm worried that it might not work out the best power wise. My gpu is overclocked is also overclocked meaning more power usage so im not sure and if i do have to upgrade what would i have to upgrade too?
https://linustechtips.com/topic/1312011-need-help/
What power supply do you have? Please list the specific model
geometry is hard
b550 > x570
https://linustechtips.com/topic/1312011-need-help/#findComment-14533344
30 series reccomended power supplies
3060: 500w
3060 ti: 600w
3070: 650w
3080:750w
3090:750w
A 3060 is totally fine for a 600w psu and even some room for overclocking
https://linustechtips.com/topic/1312011-need-help/#findComment-14533365
Power draw, it will work.
But the quality of the unit also matters. 80+ Bronze is not the highest rating (which is fine) but what is the unit?
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1312011-need-help/#findComment-14533367
https://www.amazon.com/gp/product/B01MTJTO2O/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
https://linustechtips.com/topic/1312011-need-help/#findComment-14533428
Ehhhhhhh....
I had that PSU for a few months. Its..... fine.
I would not put anything above the 3060 in there. And I would not recommend an overclock.
BUT it will work with a 3060
https://linustechtips.com/topic/1312011-need-help/#findComment-14533437
if
3 minutes ago, MarvintheParrot said:
Ehhhhhhh....
If i were to get a 3060 ti what would i put in there instead?
https://linustechtips.com/topic/1312011-need-help/#findComment-14533442
if
As a PSU upgrade, look at this: PSU tier list and anything in the A tier with at least 650W.
https://linustechtips.com/topic/1312011-need-help/#findComment-14533449
