hello i am getting this graphics card for my hp pavillion p6 specs:https://support.hp.com/gb-en/document/c03382053
the card:https://www.newegg.com/global/uk-en/msi-geforce-gt-1030-gt-1030-2gh-lp-oc/p/N82E16814137140?Item=N82E16814137140
my only question is it says
  • PCI Express 3.0 x16 (uses x4)
what does uses x4 mean i know this will work with my shitty pc cause i heard pcie express 3.0 is backwards compatible to my pcie express 2.0 slot
Thanks
( i know i worded this in the most annoying way possible sorry)
https://linustechtips.com/topic/1310400-help/
The X defined is basically how many lanes of that connection it's going to use or need to run properly. So it's saying it runs on a 16x slot but only needs 4x of those available lanes. In the case where you have PCI express slots that aren't full 16x, you could use one of these cards on a 4x or 8x slot. In terms of backwards compatibility you should also be fine as it isn't really demanding that much bandwidth if it can run on 4x.
System Specs: (Click Expand)
          "Beatrix"
  • CPU AMD Ryzen 7 5800x3D
  • Motherboard GIGABYTE X570 I AORUS Pro Wi-Fi
  • RAM 2 x 16GB Corsair Vengeance RGB Pro @ 3200mhz CL16
  • GPU Gigabyte Eagle RX 6700XT
  • Case Corsair Crystal 280x
  • Storage 1x Samsung 980 Pro (1TB) 1x Samsung 970 Evo Plus (500GB) 1x Samsung 860 Evo (1TB)
  • PSU EVGA G5 850W
  • Display(s) 32" Odyssey Neo G7 & 27" Viewsonic XG2705
  • Cooling Corsair H100i Elite Capellix AIO | 4x QL120 RGB fans | 2x QL140 RGB fans
  • Keyboard Logitech G Pro
  • Mouse Logitech G502 Lightspeed /w Powerplay
  • Sound Logitech G Pro Wired
  • Operating System Windows 11 Professional 23H2
https://linustechtips.com/topic/1310400-help/#findComment-14520796
