Okay so I'm using CM11 nightlies on my LG G2.. and I need some help using the updater.  Basically with the G2 (Sprint LS980 version) if you want to use 4GLTE and take advantage of 'sprint spark' you have to flash either the furnace kernel or dr87's kernel on top of CM11 to get it to boot.  So when I tried to use the updater, I obviously got stuck in a boot loop =_=.  So I flashed the dr87 kernel and BOOM it booted!  So it said updating apps...please wait... and everything looked fine until it started saying android.service.com (or something similar) has stopped working.  So I flashed back to stock using TWRP and now I'm just curious if I can even use the autoupdater on the G2 until CM11 patches the LS980 kernel?
THANKS
Linux "nerd".  If I helped you please like my post and maybe add me as a friend :)  ^_^!
https://linustechtips.com/topic/130962-rom-help/
OH CRAP I didn't.  Would that do the trick?  shiieeeeeeeet
Worked for me last time (I think. I vaguely remember forgetting to flash gapps and having some "stopped working" issue).
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/130962-rom-help/#findComment-1743635
Thanks a ton.
https://linustechtips.com/topic/130962-rom-help/#findComment-1743663
