Radeon Workstation?
Solved by Electronics Wizardy,
22 minutes ago, d4n1Xd34th said:But can reading from the old posts, softwares like Vray will suffer in Non nvidia cards as Vray uses CUDA?
If the program is cuda only, it won't work at all on amd cards, or not with out a lot of tweaking and work for a conversion layer. Vray doesn't seem to work at all on amd gpus now.
Id really go nvidia here, they are just much better support in the gpu compute market with cuda.
Also blender can use optix which speeds ups renders a good amount.
