Just now, DSTECH said:
Full PC specs.
and windows installed on hdd or ssd.
any software update running or anti virus software.
ryzen 5 2600
msi mortar max b450
gtx 1650 super
2x8 gb ram 3200mhz
kingston ssd 200+gb (i forgot the exact size)
seagate hdd 1tb
psu corsair 450w bronze
win 10
windows security
no updates
14 minutes ago, charliellantino said:
ryzen 5 2600
msi mortar max b450
gtx 1650 super
2x8 gb ram 3200mhz
seagate hdd 1tb
win 10
windows security
no updates
Have you tried enable - disable fast boot in windows 10 and
any extra software you are using like for multimedia or heavy load programming work
and windows 10 installed in ssd
is your hdd is working may be its getting old or having problem or full space.
I haven't tried disable fast boot in windows 10 actually i didn't know that. I have softwares like autocad, and adobe softwares. Yes os is installed in ssd, my hdd is also new and have 700+ gb free space. I even noticed that when booting up it is little bit slower than before.
As you have installed heavy process softwares they take time to close.
Disable uninstall some windows feature and windows apps (which are not in use)  in app section.
Okay thanks for the info i'll try them
